[GRASS-dev] wxpython not building automatically in GRASS 7
Fri Apr 2 18:58:24 EDT 2010
Colin (Nielsen) Wren wrote:
> The wxpython dir was moved to gui/wxpython (r41557) by martinl. If
> you're getting the same error as I was then then this should fix it.
> I posted before with a one line fix, but two lines need changing I think:
> Index: functions.sh
[snip]
Okay; committed in r41675.
