Fwd: [GRASS-dev] Fwd: [GRASS-user] How to embed a grass script
	(for example v.db.addcol) into a Pythonscript on windows?
    Helmut Kudrnovsky
    hellik at web.de
    Sat Apr  3 15:07:27 EDT 2010
>>Von: Michael Barton <Michael.Barton at asu.edu>
>>In a related question, maybe more for Colin, does GRASS 7 work in
>>Windows? If so, what is the setup to allow it to run the scripts in
>>Python?
>GRASS 7 works in Windows using a similar batch file to that which I
>posted for 6.x. However, the Init.bat file needs some work. Starting
>with -wxpython doesn't work (you can start it manually via g.gui,
>though). If you start in -text mode, you'll get a couple of errors
>about the missing set_data program, but you'll end up in a session
>using the existing .grassrc7 file (provided that one exists).
for testing there is a nightly build of WinGrass7:
http://grass.osgeo.org/download/software.php
http://josef.fsv.cvut.cz/wingrass/grass70/
best regards
Helmut
___________________________________________________________
NEU: WEB.DE DSL für 19,99 EUR/mtl. und ohne Mindest-Laufzeit!
http://produkte.web.de/go/02/
