[GRASS-dev] about simple feature/ogr direct processing
G. Allegri giohappy at gmail.com
Tue Apr 6 11:45:08 EDT 2010
Ok, I see in http://trac.osgeo.org/grass/changeset/39161. The core
work is done in open.c depending on the @Mapset name. If it's 'ogr'
the vectors are opened as direct ogr, and level 1 (without topoloy).
So also polygons can be opened as level 1?
giovanni
2010/4/6 Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2010/4/6 G. Allegri <giohappy at gmail.com>:
>> I admit that this news has raised new interest in me, and some
>> collegues of mine. I've given a look at the code, to see what is
>> needed to make the v.* commands support direct ogr, but I haven't been
>> able to highlight where the "magics" is done... Martin, or others,
>> could you indicate me an example?
> see [1] for details about implementation issues. I hope it helps.
> Direct read OGR access is completely untested, any kind of
> contribution is welcomed.
> Martin
> [1] http://trac.osgeo.org/grass/wiki/Grass7/VectorLib/OGRInterface
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
