[GRASS-dev] about simple feature/ogr direct processing
G. Allegri giohappy at gmail.com
Wed Apr 7 09:00:42 EDT 2010
Citing from http://download.osgeo.org/grass/grass7_progman/vectorlib.html#vlibTopoManagement
"Topology is written for native format while pseudo-topology is
written for OGR sources, SHAPE-link."
Please, forgive me, but I would like to clarify some points more.
1 - v.external links to data without topology buing built. At the
moment it's only useful for visualizing (but could it be used for SF
algorithms?)
2 - OGR data sources use "pseudo-topology". Does this refer to the
read/write directly accessed sources? Or is it general? What is the
main difference between pseudo- and real- topology?
thanks again,
giovanni
2010/4/6 Martin Landa <landa.martin at gmail.com>:
> [back to ML]
> Hi,
> 2010/4/6 G. Allegri <giohappy at gmail.com>:
>> So it's not meant to be used for ogc simple featurer processing (like
>> in qgis or saga). The topo build step is required for processing. I
>> thought it was an option to permit the development/use of
>> not-topological algorithms...
> it's question for discussion, currently no SF processing implemented
> in GRASS AFAIK.
> Martin
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
