[GRASS-dev] Re: [GRASS GIS] #928: 6.4: wx module GUIs never return
trac at osgeo.org
Thu Apr 8 04:47:48 EDT 2010
Reporter: hamish | Owner: martinl
Type: defect | Status: assigned
Priority: critical | Milestone: 6.4.0
Component: default | Version: svn-releasebranch64
Resolution: | Keywords: addons
Platform: Linux | Cpu: x86-64
Comment (by marisn):
Replying to [comment:17 hamish]:
>that is due to the way that the icons/menu items are set up on WinGrass.
If you look at the Properties they actually call "`grass64 -tcltk`" and
"`grass64 -wxpython`". Which has the effect of making the selection
permanent. Solution: if you want the tcltk gui click on the tcltk menu
item, if you want the wx gui click on the wx gui menu item. copy either
one to your desktop as desired.
> Hamish
Ah. That explains a bit, still I was using `grass64 -text`, as it gives me
CMD. Lack of normal terminal is PITA. Also then probably g.gui should
print a warning when launched with -u on windows, as I expect my later
actions to take precedence over startup type.
Ticket URL: <https://trac.osgeo.org/grass/ticket/928#comment:18>
