[GRASS-dev] GRASS_EXTRA_PATHS and GRASS_EXTRA_LIBS for importing
extra working environments?
Glynn Clements
glynn at gclements.plus.com
Thu Apr 8 22:54:28 EDT 2010
Alessandro Frigeri wrote:
> At the moment I'm using system's LD_LIBRARY_PATH for adding specific
> extra libs, and GRASS_ADDON_PATH to add extra scripts and executables I
> want to use within GRASS GIS.
> Especially for the case of some specific libraries, these are mostly
> useful within the data analysis session -- and are not useful as
> system-wide libraries, so I ended up with a custom Init.sh script that
> set them for me within the GRASS session.
Note that you can use ~/.grass.bashrc for commands which are to be run
at the beginning of a GRASS session.
