[GRASS-dev] [GRASS GIS] #1032: ErrorCommandExecution g.proj
GRASS GIS trac at osgeo.org
Sat Apr 10 05:11:16 EDT 2010
 Reporter:  sallar        |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect        |      Status:  new
 Priority:  blocker       |   Milestone:  6.4.0
Component:  wxGUI         |     Version:  6.4.0 RCs
 Keywords:  g.proj,wxGUI  |    Platform:  Linux
      Cpu:  x86-32        |
 By starting with grass wxgui, hangs with the following error [1][[BR]]
 In the shell appears as follows:
 File "/usr/local/grass-6.4.0RC6/etc/wxpython/gui_modules/wxgui_utils.py",
 line 84, in __init__
     self.Map = render.Map()    # instance of render.Map to be associated
 with display
   File "/usr/local/grass-6.4.0RC6/etc/wxpython/gui_modules/render.py",
 line 402, in __init__
     self.projinfo = self.ProjInfo()
 line 765, in ProjInfo
     p = gcmd.Command(['g.proj', '-p'])
   File "/usr/local/grass-6.4.0RC6/etc/wxpython/gui_modules/gcmd.py", line
 369, in __init__
     _("Error: ") + self.GetError()))
 gui_modules.gcmd.CmdError
 [1]-http://www.filedropper.com/errorincommandexecutiongproj
Ticket URL: <http://trac.osgeo.org/grass/ticket/1032>
