[GRASS-dev] Nviz build (Grass70)
Massimo Di Stefano massimodisasha at gmail.com
Sat Apr 10 05:36:04 EDT 2010
Tring to build Grass70 on debian sid (ffmeg installed from source svn)
i get an error building Nviz, the same configure used to build grass65
give me no errors and Nviz works fine on grass65.
cd /usr/local/src/gis/grass_trunk/visualization/nviz
 make
make -C src
make[1]: Entering directory `/usr/local/src/gis/grass_trunk/visualization/nviz/src'
: && gcc -L/usr/local/src/gis/grass_trunk/dist.x86_64-unknown-linux-gnu/lib -L/usr/local/src/gis/grass_trunk/dist.x86_64-unknown-linux-gnu/lib -Wl,--export-dynamic -Wl,-rpath-link,/usr/local/src/gis/grass_trunk/dist.x86_64-unknown-linux-gnu/lib   -o /usr/local/src/gis/grass_trunk/dist.x86_64-unknown-linux-gnu/bin/nviz OBJ.x86_64-unknown-linux-gnu/anim_support.o OBJ.x86_64-unknown-linux-gnu/change_view.o OBJ.x86_64-unknown-linux-gnu/cutplane_obj.o OBJ.x86_64-unknown-linux-gnu/do_zoom.o OBJ.x86_64-unknown-linux-gnu/draw.o OBJ.x86_64-unknown-linux-gnu/exag.o OBJ.x86_64-unknown-linux-gnu/glwrappers.o OBJ.x86_64-unknown-linux-gnu/init_commands.o OBJ.x86_64-unknown-linux-gnu/label.o OBJ.x86_64-unknown-linux-gnu/lights.o OBJ.x86_64-unknown-linux-gnu/map_obj.o OBJ.x86_64-unknown-linux-gnu/misc.o OBJ.x86_64-unknown-linux-gnu/nvizAppInit.o OBJ.x86_64-unknown-linux-gnu/nviz_init.o OBJ.x86_64-unknown-linux-gnu/nvizMain.o OBJ.x86_64-unknown-linux-gnu/pick_vect_commands.o OBJ.x86_64-unknown-linux-gnu/position.o OBJ.x86_64-unknown-linux-gnu/query_vect.o OBJ.x86_64-unknown-linux-gnu/quick_draw.o OBJ.x86_64-unknown-linux-gnu/script_support.o OBJ.x86_64-unknown-linux-gnu/togl.o OBJ.x86_64-unknown-linux-gnu/togl_cb.o OBJ.x86_64-unknown-linux-gnu/togl_flythrough.o OBJ.x86_64-unknown-linux-gnu/volume.o    -lgrass_ogsf -lgrass_bitmap -lgrass_linkm -lgrass_vector -lgrass_dig2 -lgrass_dgl -lgrass_rtree -lgrass_linkm -lgrass_dbmiclient -lgrass_dbmibase  -lgrass_sites -lgrass_form -lgrass_dbmiclient -lgrass_dbmibase  -lgrass_g3d -lgrass_gis -lgrass_datetime  -ltiff  -ltk8.5 -lm  -ltcl8.5 -lm -lGLU  -lGL   -lSM -lICE -lX11 -lXmu -lXext  -lm  -lm
/usr/local/src/gis/grass_trunk/dist.x86_64-unknown-linux-gnu/lib/libgrass_ogsf.so: undefined reference to `av_init_packet at LIBAVFORMAT_52'
collect2: ld returned 1 exit status
make[1]: *** [/usr/local/src/gis/grass_trunk/dist.x86_64-unknown-linux-gnu/bin/nviz] Error 1
make[1]: Leaving directory `/usr/local/src/gis/grass_trunk/visualization/nviz/src'
make: *** [default] Error 2
thanks!
Massimo.
