[GRASS-dev] Re: [GRASS GIS] #1006: r.terraflow fails to stat() stream file on Windows
GRASS GIS trac at osgeo.org
Sat Apr 10 06:05:49 EDT 2010
  Reporter:  marisn           |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  critical         |   Milestone:  6.4.0
 Component:  Raster           |     Version:  svn-releasebranch64
Resolution:                   |    Keywords:  wingrass, r.terraflow
  Platform:  MSWindows Vista  |         Cpu:  x86-32
Changes (by hamish):
  * keywords:  wxgui, wingrass, terraflow => wingrass, r.terraflow
Comment:
 - removed wxgui keyword, it also happens from the msys prompt.
 Maris: fyi extra debug messages only added in 6.5svn.
 STREAM temporary files in C:/Users/Maris/AppData/Local/Temp
 stats.out: Permission denied
 stats.out tries to write to the current working directory, try running
  cd C:/Users/Maris/AppData/Local/Temp
 or your home dir before starting the program. (or change the stats=
 filename option)
 (IIUC stats.out file just contains extra debug messages; STREAM is a copy
 of the raster map stored on disk for random access)
 testing with the latest 6.5 nightly wingrass build (r41761), it looks like
 the stat() on an open file is in fact the problem:
 #spearfish
 g.region rast=elevation.dem
 r.terraflow ele=elevation.dem filled=rterra.fill dir=rterra.dir \
   swat=rterra.swat acc=rterra.acc tci=rterra.tci mem=600
 D3/3: create window mapping (633 columns)
 C:/DOCUME~1/OPG/LOCALS~1/Temp/STREAM_a03788: length = 0   sizeof(T)=4
 D3/3: nrows=466   ncols=633    stream_len()=0
 Assertion failed: nrows * ncols == str->stream_len(), file grass2str.h,
 line 146
 # file size on disk:
 wc -c C:/DOCUME~1/OPG/LOCALS~1/Temp/STREAM_a03788
 1179912
 633*466 = 294978 cells
 1179912 / 294978 = 4 bytes per cell
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1006#comment:23>
