[GRASS-dev] Re: [GRASS GIS] #1031: More specific parameter
information in command line help
trac at osgeo.org
Sun Apr 11 09:35:14 EDT 2010
#1031: More specific parameter information in command line help
Reporter: huhabla | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: minor | Milestone: 7.0.0
Component: libgis | Version: svn-trunk
Resolution: | Keywords: parser, help
Platform: All | Cpu: All
Comment (by martinl):
Replying to [comment:2 huhabla]:
> I am aware that some of informations i requests are given by the usage
string. But IMHO it is more convenient and easier to understand
(especially for command line beginner) to make these informations also
available in the help description. My enhancement request is only related
to the command line. It does not touch the automated gui generation.
I think that the beginners usually do not use CLI at all. At least 'type'
and 'required' are redundant info
input Name of input raster map
status: input
type: cell
required: yes
We could use {{{key_desc}}} attribute for defining prompt type.
input=raster
instead of
input=name
The question is how to handle 'status' of the options.
> The usage string does not always provide the convenient information if
the parameter is of type raster, vector, volume, integer or float. In many
modules input and output parameter are named related to the modules
purpose, the information if its an input or output is only present if you
read the help page.
Right, it could be improved by better {{{key_desc}}} usage.
> Martin Landa currently renamed in several modules the input and output
parameter to make clear which of them are inputs or outputs. I.e:
elevation -> elevation_input, direction -> direction_output, but this is
IMHO not a good idea. It is redundant information, especially if you are
using the gui.
Right, see [wiki:Grass7/NewFeatures#Renamedoptions Rename options]. Your
idea about 'status' info seems to be better solution. If you prefer I can
remove '_input/optput' from paramaters key string.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1031#comment:3>
