[GRASS-dev] Re: [GRASS GIS] #1031: More specific parameter
information in command line help
trac at osgeo.org
Mon Apr 12 09:16:57 EDT 2010
#1031: More specific parameter information in command line help
Reporter: huhabla | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: minor | Milestone: 7.0.0
Component: libgis | Version: svn-trunk
Resolution: | Keywords: parser, help
Platform: All | Cpu: All
Comment (by huhabla):
I have attached a patch for lib/gis/parser_help.c and
lib/gis/parser_stanndard_options.c which implements the discussed ideas.
Examples:
lib/gis> r.neighbors help
Description:
Makes each cell category value a function of the category values assigned
to the cells around it, and stores new cell values in an output raster map
layer.
Keywords:
raster
Usage:
r.neighbors [-ac] input=raster [selection=raster] output=raster
[method=string] [size=value] [title=phrase] [weight=filename]
[gauss=value] [quantile=value] [--overwrite] [--verbose] [--quiet]
Flags:
-a Do not align output with the input
-c Use circular neighborhood
--o Allow output files to overwrite existing files
--v Verbose module output
--q Quiet module output
Parameters:
input Name of input raster map
selection Name of an input raster map to select the cells which should
be processed
type: input
output Name for output raster map
method Neighborhood operation
options: average,median,mode,minimum,maximum,stddev,sum,
variance,diversity,interspersion,quart1,quart3,perc90,
quantile
default: average
size Neighborhood size
default: 3
title Title of the output raster map
weight Text file containing weights
gauss Sigma (in cells) for Gaussian filter
quantile Quantile to calculate for method=quantile
options: 0.0-1.0
default: 0.5
lib/gis> r.buffer2 help
Description:
Creates a raster map layer showing buffer zones surrounding cells that
contain non-NULL category values.
Keywords:
raster, buffer
Usage:
r.buffer2 [-z] input=raster output=raster distances=value[,value,...]
[units=string] [--overwrite] [--verbose] [--quiet]
Flags:
-z Ignore zero (0) data cells instead of NULL cells
Parameters:
distances Distance zone(s)
units Units of distance
options: meters,kilometers,feet,miles,nautmiles
default: meters
lib/gis> r.gwflow help
Description:
Numerical calculation program for transient, confined and unconfined
groundwater flow in two dimensions.
Keywords:
raster, groundwater flow
Usage:
r.gwflow [-f] phead=raster status=raster hc_x=raster hc_y=raster
[q=raster] s=raster [recharge=raster] top=raster bottom=raster
output=raster [vx=raster] [vy=raster] [budget=raster] type=string
[river_bed=raster] [river_head=raster] [river_leak=raster]
[drain_bed=raster] [drain_leak=raster] dt=value [maxit=value]
[error=value] [solver=name] [--overwrite] [--verbose] [--quiet]
Flags:
-f Allocate a full quadratic linear equation system, default is a
sparse linear equation system.
Parameters:
phead The initial piezometric head in [m]
type: input
status Boundary condition status, 0-inactive, 1-active,
2-dirichlet
type: input
hc_x X-part of the hydraulic conductivity tensor in [m/s]
type: input
hc_y Y-part of the hydraulic conductivity tensor in [m/s]
type: input
q Raster map water sources and sinks in [m^3/s]
type: input
s Specific yield in [1/m]
type: input
recharge Recharge map e.g: 6*10^-9 per cell in [m^3/s*m^2]
type: input
top Top surface of the aquifer in [m]
type: input
bottom Bottom surface of the aquifer in [m]
type: input
output The map storing the numerical result [m]
vx Calculate and store the groundwater filter velocity vector
part in x direction [m/s]
type: output
vy Calculate and store the groundwater filter velocity vector
part in y direction [m/s]
type: output
budget Store the groundwater budget for each cell [m^3/s]
type: output
type The type of groundwater flow
options: confined,unconfined
default: confined
river_bed The height of the river bed in [m]
type: input
river_head Water level (head) of the river with leakage connection in
[m]
type: input
river_leak The leakage coefficient of the river bed in [1/s].
type: input
drain_bed The height of the drainage bed in [m]
type: input
drain_leak The leakage coefficient of the drainage bed in [1/s]
type: input
dt The calculation time in seconds
default: 86400
maxit Maximum number of iteration used to solver the linear
equation system
default: 100000
error Error break criteria for iterative solvers (jacobi, sor, cg
or bicgstab)
default: 0.0000000001
solver The type of solver which should solve the symmetric linear
equation system
options: cg,pcg,cholesky
default: cg
Ticket URL: <http://trac.osgeo.org/grass/ticket/1031#comment:5>
