[GRASS-dev] diglib test.c fails on 64bit win
Markus Neteler
neteler at osgeo.org
Mon Apr 12 14:44:39 EDT 2010
On Mon, Apr 12, 2010 at 8:40 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> test in diglib fails (trunk) on MS Windows 64bit
> landa at GEO1 /osgeo4w/usr/src/grass_trunk/lib/vector/diglib
> $ make
> if [ "" != "" -a -f "".html ] ; then make html ; fi
> ==============TEST=============
> make test
> make[1]: Entering directory `/osgeo4w/usr/src/grass_trunk/lib/vector/diglib'
> diff OBJ.i686-pc-mingw32/test.tmp test64.ok
> Files OBJ.i686-pc-mingw32/test.tmp and test64.ok differ
> make[1]: *** [test] Error 2
> make[1]: Leaving directory `/osgeo4w/usr/src/grass_trunk/lib/vector/diglib'
> make: *** [default] Error 2
> Not sure how to fix it. Any pointer welcomed. Martin
Do you have LFS active?
http://trac.osgeo.org/grass/ticket/930#comment:1
Markus
