[GRASS-dev] Re: [GRASS GIS] #1031: More specific parameter
information in command line help
trac at osgeo.org
Tue Apr 13 09:56:11 EDT 2010
#1031: More specific parameter information in command line help
Reporter: huhabla | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: minor | Milestone: 7.0.0
Component: libgis | Version: svn-trunk
Resolution: | Keywords: parser, help
Platform: All | Cpu: All
Comment (by martinl):
Replying to [comment:6 glynn]:
> Replying to [comment:5 huhabla]:
> > I have attached a patch for lib/gis/parser_help.c and
lib/gis/parser_stanndard_options.c which implements the discussed ideas.
> 1. The patch makes unnecessary formatting changes, which also contravene
the GRASS formatting conventions. In general, formatting changes should be
kept separate from other changes to make it easier to review the substance
of the changes. But in this case, the formatting changes just shouldn't be
there.
> 2. The updated output is unnecessarily verbose, which is a bad thing
IMHO. The "required" and "multiple" status can already be determined from
the "Usage:" section. Non-required options are listed in square brackets,
while multiple options use the "option=value,..." convention. If you
really want this format, it should be a separate option, e.g. --verbose-
help.
Probably we should think about the optimalization of the attributes in
struct Option (1) Currently we have:
struct Option
const char *key;
int type;
int required;
int multiple;
const char *options;
const char **opts;
const char *key_desc;
const char *label;
const char *description;
const char *descriptions;
const char **descs;
char *answer;
const char *def;
char **answers;
struct Option *next_opt;
const char *gisprompt;
const char *guisection;
const char *guidependency;
int (*checker) ();
int count;
Parsed for wxGUI, e.g.
{'gisprompt': True, 'multiple': 'no', 'description': 'Name for output
vector map', 'guidependency': '', 'default': '', 'age': 'new', 'required':
'yes', 'value': 'lakes_buff', 'label': '', 'guisection': u'Required',
'key_desc': ['name'], 'values': [], 'values_desc': [], 'prompt': 'vector',
'wxId': [-327], 'element': 'vector', 'type': 'string', 'name': 'output'}
I would suggest:
* if 'key_desc' is NULL then use as 'key_desc' 'prompt' value
* do we need 'element' attribute - it could be probably replaced by
'prompt'
* suggested 'status' info is determined from 'prompt' and 'age'
attribute.
(1)
http://download.osgeo.org/grass/grass7_progman/gislib.html#Complete_Structure_Members_Table
Ticket URL: <http://trac.osgeo.org/grass/ticket/1031#comment:7>
