[GRASS-dev] GNU scientific library in GRASS
Jarek Jasiewicz
jarekj at amu.edu.pl
Tue Apr 13 11:48:44 EDT 2010
Soeren Gebbert pisze:
> Hello,
> 2010/4/13 Jarosław Jasiewicz <jarekj at amu.edu.pl>:
>> Hi All!
>> What about using GNU scientific library (gsl) in GRASS module?
>> Will it create additional dependencies?
> Yes.
>> What about compiling on windows?
>> Any other contraindications??
>> In general what I want to use I cannot find in gmath library.
> What kind of algorithms are missing in gmath library?
thanks for answer and hint.
In general I have almost created module (v.surf.trend) to fit
polynominal 2,5D surface to set of points (in theory any order of
plynominal, but in fact up to 6 or 10 order).
I used for it gsl_multifit_linear and gsl_multifit_linear_svd wich work
for now well on sample dataset
now I try to expeand it with some addational functions like
gsl_multifit_wlinear and gsl_multifit_linear_est (rather experimentally)
and finally must create GRASS io and interface section to finish it.
I look into ccmath and what I found is pplsq, but I'm not sure I will
easily expand it to 2D surface (it differs form gsl which is genearlly
based on "Numerical recipies..."). I do not know ccmath I saw it for
the first time so I cannot surely say there is all I need.
In general it is possible to solve problem with some additional
programing effort but with gsl I have given solution.
On the other hand gsl is in practice available in almost all linux
installation except these most limited...
Again thanks for answer. I think now I will finish it on my way and
start test, and next I can think about rewrite it with ccmath for GRASS 7
Jarek.
> GRASS7 already includes a numerical library called ccmath. Have a look
> in the gmath-ccmath wrapper in lib/gmath.
> Currently only a few algorithms from ccmath are used: eigenvalue
> computation, LU decomposition and SVD solver. Have a look at the
> ccmath library (http://freshmeat.net/projects/ccmath/). Maybe the
> algorithms you are searching for is present there? If this is the case
> we can add it to grass7.
> Sören
>> thanks for any answer
>> J.
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
