[GRASS-dev] wxGUI modeler
Soeren Gebbert
soerengebbert at googlemail.com
Thu Apr 15 04:09:54 EDT 2010
Hello Martin,
this is really great. The GRASS community is waiting for such a tool
for many, many years.
At work i have implemented a back-end for a graphical modeler which is
based on XSD/XML and Python.
It is designed to automatically compute and consider the process
dependencies and to execute independent processes in parallel. It can
process huge, complex process chains with multiple start- and
end-points.
If you are interested in my experience, don't hesitate to ask. I may
be able to help a bit. :)
Best regards
Soeren
2010/4/14 Martin Landa <landa.martin at gmail.com>:
> Hi,
> some days ago I started working on the new graphical modeler for wxGUI
> [1]. Modeler is currently available in GRASS 7.0 and GRASS 6.5 [2].
> It's aplha version with very limited functionality. See also flash
> example how to create a simple model [3].
> Martin
> [1] http://grass.osgeo.org/wiki/WxGUI_Modeler
> [2] https://svn.osgeo.org/grass/grass/trunk/gui/wxpython/gui_modules/gmodeler.py
> [3] file:///home/martin/wxgui-modeler-0.html
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
