[GRASS-dev] Re: [GRASS GIS] #1039: i.group segmentation fault using
full path name
trac at osgeo.org
Thu Apr 15 17:35:17 EDT 2010
#1039: i.group segmentation fault using full path name
Reporter: huhabla | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: closed
Priority: major | Milestone: 7.0.0
Component: Imagery | Version: svn-trunk
Resolution: fixed | Keywords: group
Platform: Linux | Cpu: x86-32
Changes (by huhabla):
* status: new => closed
* resolution: => fixed
Comment:
The error is related to the I_location_info(title, argv[0]) call before
line 112 and the size of the title buffer. The consequence is a buffer
overflow resulting in a segfault.
The I_location_info() function is implemented quite unsafe using sprintf
without checking the buffer length. It is always a bad idea to fill a
buffer with an unknown length. I have fixed this in svn [41880] and
removed the unused I_location_info() call from i.group.
It seems to me that I_location_info() is not used by any imagery module?
Could it be removed?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1039#comment:1>
