[GRASS-dev] Re: [GRASS GIS] #1031: More specific parameter
information in command line help
trac at osgeo.org
Sun Apr 18 10:04:02 EDT 2010
#1031: More specific parameter information in command line help
Reporter: huhabla | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: minor | Milestone: 7.0.0
Component: libgis | Version: svn-trunk
Resolution: | Keywords: parser, help
Platform: All | Cpu: All
Comment (by glynn):
Replying to [comment:14 huhabla]:
> I have implemented a simple prototype, to get an idea how this may work.
Files are attached. Do you think my implementation points in the right
direction?
I think that it's too early to be bothering with implementation details
right now. I'd rather clarify the concept then the interface.
> > Variadic functions could either use a prefixed count or a NULL
terminator (but the latter won't work for numbers).
> > You would also need dependent base types, e.g. "column name within the
database table associated with the map specified by the input= option".
> I am not sure if i understand that, What is the benefit of dependent
base type?
I'm talking about the situation where the set of valid values for one
option is dependent upon the value of another option. E.g. for options
which specify the name of a database column, valid values are column names
in a particular table, typically the table associated with a specific map.
E.g. for d.vect, there are rgb_column=, wcolumn=, size_column=,
rot_column=, and attrcolumn= options; valid values for these options are
column names from the table associated with the map specified by the map=
option. Ideally, the GUI would be able to offer a list of column names
once the user has chosen a map.
IIRC, at present the GUI updates the list whenever the user chooses a map.
If a module has more than one option whose value is a vector map name, the
GUI has no way of knowing which one determines the set of valid column
names.
Similar issues exist if valid option values are categories within a raster
map, or cell values within the map's range, or coordinates within the
map's bounds, subgroups within an imagery group, etc.
> > When it comes to parsing, you could implement such types using a
generic mechanism using a callback function to enumerate or validate
allowed values; however, we need to think about how this interacts with
the GUI.
Right. This is why I'm inclined towards a "closed sum" approach, with a
finite, fixed set of base types and constructors. Having the GUI invoke
the module to execute a call-back should be a last resort. Apart from
efficiency issues, it forces the GUI to use a generic interface rather
than more specialised interfaces.
> I think your approach has enormous potential, but i am also concerned
that it may be to complicated for grass module programmers?
Most modules will only need relatively straightforward types, e.g. "raster
map name". The most common cases will just use G_define_standard_option().
Still-common but more complex cases (e.g. a database column for a
particular map) can have utility functions written for them.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1031#comment:15>
