[GRASS-dev] v.external, ogr direct access, topology and
pseudo-topology.... a bit confused
G. Allegri
giohappy at gmail.com
Mon Apr 19 08:50:29 EDT 2010
Hi Markus,
thanks for the clarifying reply.
For SF algorithms I mean those that can apply to SF structures, as meant by
the OGC definition. For example a simple clip based on the SF spatial
operators (like those in v.select in GRASS 7).
It's not uncommon to need these operations rapidly, even on unclean data (at
least, this happens frequently between my collegues and practioners). Much
strict correctness is often not required, for daily work...
But from your explanation I understand that with pseudo-topology Grass can
digest unclean polygons too... so I suppose that these kind of operations
(like a clip) can be rapidly made through direct OGR read access. Even with
v.external? (I have to verify, because I don't have GRASS 7 right now on
this pc).
giovanni
[1] OpenGIS® Implementation Specification for Geographic information -
Simple feature access - Part 1: Common architecture, Chapter 6
http://portal.opengeospatial.org/files/?artifact_id=18242
2010/4/19 Markus Metz <markus.metz.giswork at googlemail.com>
> G. Allegri wrote:
>> I open a new post on the argument because it's something more general
>> that me and my collegues need to unsertstand.
>> I've tried to make the point with the various vector structures and
>> modes in grass7 and I admit to be a bit confused.
>> - v.external is meant to read ogr data sources without the
>> topoloigcal overhead.
> By default, pseudo-topology and a spatial index is built for both
> v.external and direct OGR access.
> Questions:
>> - what is meant by pseduo-topology?
> Reduced topology: each boundary is attached to one area only, i.e.
> smoothing, simplification, removing small areas etc. will not work properly
> for adjacent areas or areas within areas.
>> - does the 'b' option is referred to pseudo-topology creation? If
>> I set it, I cannot see the map and the "zoom to selected map" gives me
>> an empty error box...
> ... because the extends of a vector map are stored in topology, also in
> pseudo-topology. If topology and thus the extends are not available, "zoom
> to selected map" won't work. And yes, the 'b' option refers to
> pseudo-topology.
>> - direct read/write access creates the same topo structure as native
>> access, but it builds it each time I open the data source. Am I wrong?
>> Is it too simplicistic my understanding?
> No, it also builds pseudo-topology, not native full topology, this is only
> available for native GRASS vectors. Full, correct topology can only be built
> after all polygons are cleaned as done by v.in.ogr.
>> My first concern is about the use of simple features in the grass
>> environment, and tha ability to write SF algorithms
> Can you give examples for such SF algorithms/operators? It's not clear to
> me what you have in mind.
>> that don't require
>> topology to be built. This is a requirement in daily work, mostly when
>> we deal with unclean polygonal data but the topology is not required
>> (ie simple feature operators, etc.).
> GRASS is rather strict about polygonal data. Working with unclean polygonal
> data will produce unclean results which is not desired IMHO.
> It seems to me that you are missing some functionality in GRASS, so it
> would be great if you could give some examples about what is missing.
> Markus M
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100419/69d746dc/attachment.html
