[GRASS-dev] #1036: empty monitor in i.pr.classify
    António Rocha
    antonio.rocha at deimos.com.pt
    Tue Apr 20 07:15:31 EDT 2010
Greetings
Regarding this problem I decided to compare r.le.setup function with
i.pr.classify to identify what might not be working-
Apparently everything seems to be working but, in the case of r.le.setup
the dispay in the panel is defined by #include <grass/display.h> and in
the case of i.pr.classify it uses a graphics.c function. Has anyone some
experience in dealing with this displays functions in order to identify
why i.pr.classify is not properly displaying rasters in the xterm.
Thanks
Best regards
Antonio
Markus Neteler wrote:
> 2010/4/16 António Rocha <antonio.rocha at deimos.com.pt>:
>> Greetings
>> I have testes this function and even with "black" panels it does work and
>> saves a few signature files. The thing is that the rasters are not displayed
>> in x0 monitor. Does anyone knows what might not be ok or what
>> libraries/packages am I missing?
> AFAIK i.pr.* was written for GRASS 5.x by my former colleague.
> It is almost certain that more code updates are needed to use
> it with GRASS 6.
> To achieve this, you need to compare similar modules in GRASS
> 6 with i.pr.* code. Certainly the modules are different, but yet they
> will be quite similar concerning the I/O and display functions
> which is the part which likely lacks updates.
> Markus
> __________ Information from ESET NOD32 Antivirus, version of virus signature database 5040 (20100419) __________
> The message was checked by ESET NOD32 Antivirus.
> http://www.eset.com
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5042 (20100419) __________
http://www.eset.com
