[GRASS-dev] Re: [GRASS GIS] #657: add --with-openmp support to
./configure
trac at osgeo.org
Wed Apr 21 01:51:26 EDT 2010
#657: add --with-openmp support to ./configure
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: task | Status: new
Priority: normal | Milestone: 7.0.0
Component: Compiling | Version: svn-trunk
Resolution: | Keywords: openmp
Platform: All | Cpu: All
Changes (by hamish):
* cc: huhabla (added)
Comment:
wrt trunk/lib/gpde/Makefile, does -lgomp have to be before $(GMATHLIB) and
-lm or could we do
EXTRA_LIBS += -lgomp
later?
should we do the same "+=" trick for EXTRA_CFLAGS=-fopenmp, to stop it
from clobbering any earlier setting?
hopefully when this wish is fulfilled these things could be added as
needed with a permanent ifdef in the Makefile(s). (do that centrally in
grass's libmath or in the couple of library/modules that would use it?)
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/657#comment:1>
