[GRASS-dev] Re: [GRASS GIS] #879: Add a "change language" option in
GRASS GUI
trac at osgeo.org
Wed Apr 21 02:30:09 EDT 2010
#879: Add a "change language" option in GRASS GUI
Reporter: antoniorocha | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: unspecified
Resolution: | Keywords:
Platform: Unspecified | Cpu: Unspecified
Comment (by neteler):
Replying to [comment:1 glynn]:
> Is there some reason why GRASS shouldn't just use the same locale
settings as every other application?
Yes: If I am visiting for example Japan/China/Brasil/... I am not
necessarily
able to understand the local language, i.e. use the localized menus of the
PC
provided to me.
> Currently, this doesn't work on Windows, as localisation relies upon the
LANG/LC_* environment variables being set, and Windows doesn't set those,
so init.bat needs the fix proposed [http://lists.osgeo.org/pipermail/
grass-dev/2010-January/048065.html here] or something similar.
> This should probably be closed as "invalid" once someone opens a bug
report for LANG not being set on Windows.
If it is better to have a separate bug report for this, let's do it. But
it won't change
the need for a solution.
Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/879#comment:3>
