[GRASS-dev] Re: [GRASS GIS] #1041: winGRASS Tcl/Tk: Cannot save image files (PNG/JPG/BMP/etc)
GRASS GIS trac at osgeo.org
Thu Apr 22 00:34:59 EDT 2010
  Reporter:  ege           |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  closed
  Priority:  normal        |   Milestone:  6.4.0
 Component:  Tcl           |     Version:  svn-releasebranch64
Resolution:  wontfix       |    Keywords:  wingrass
  Platform:  MSWindows XP  |         Cpu:  x86-32
Changes (by hamish):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 Replying to [comment:4 ege]:
 > The path to gdal's "bin" folder was not in the %PATH%. After
 > adding it, the image file save works also from Tcl/Tk. So it's
 > an OSGeo4W-related issue, I assume.
 Yes.
 > Actually, we were focusing on GRASS for that training, but you
 > know, when you start by introducing the concept of open source
 > and OSGeo software in general, it's nice to show students (who
 > never approached FOSS4G before) that there is a convenient way
 > for installing everything easily.
 it is true that Open Source is best thought of as an ecosystem rather than
 a series of independent islands. Having the full range of gdal command
 line tools, to part command line part GUI like GRASS, to full GUI like
 QGIS lets you use the best tool for the job each time wrt each's strength.
 Having said that the stand-alone WinGRASS installer is a lot less more
 familiar/easier for new users (me too).
 > Maybe next time we will use the stand-alone installer for GRASS-focused
 > trainings.
 shrug, when ready grab the latest version of each, try both yourself, see
 which one is the better fit for you. A goal is to have both working
 properly. :)
 There is not much we can do about the PATH issue from here, so opened as
 OSGeo4W bug:
   https://trac.osgeo.org/osgeo/ticket/562
 and closing this ticket. sorry there isn't a "cantfix" option for closing
 the bug; "wontfix" isn't exactly true but is the closest available.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1041#comment:5>
