[GRASS-dev] Re: [GRASS GIS] #799: Add -o option to muliple import
of GDAL data
trac at osgeo.org
Thu Apr 22 05:51:34 EDT 2010
#799: Add -o option to muliple import of GDAL data
Reporter: trochtaj | Owner: martinl
Type: enhancement | Status: reopened
Priority: normal | Milestone: 6.5.0
Component: wxGUI | Version: unspecified
Resolution: | Keywords: import, multi
Platform: All | Cpu: Unspecified
Comment (by martinl):
Replying to [comment:9 mmetz]:
> > Right, dialog was written for shp/tiff/dxf.
> Shouldn't the multi-import dialog be written for GDAL/OGR format instead
of file name extensions? Multiple raster import using GDAL imports several
raster bands from several datasources at once, while multiple vector
import using OGR imports multiple vector layers from only one datasource
in case of e.g. shapefiles and multiple vector layer from multiple
datasources in other cases e.g. gpx or kml. Although the two dialogs look
identical, they behave different, and for multiple vector import,
behaviour depends on the selected OGR format. BTW, multiple raster import
also uses the term layer whereas it's datasources that are listed, the
layers (raster bands) are not listed.
Please, check out improved import dialog, see
http://grass.osgeo.org/wiki/WxGUI#Import_vector_data
Ticket URL: <http://trac.osgeo.org/grass/ticket/799#comment:11>
