[GRASS-dev] Re: [GRASS GIS] #958: v.krige does not run in GRASS 7
GRASS GIS trac at osgeo.org
Sat Apr 24 03:38:10 EDT 2010
  Reporter:  cmbarton  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  normal    |   Milestone:  7.0.0
 Component:  Vector    |     Version:  svn-trunk
Resolution:            |    Keywords:  krige
  Platform:  All       |         Cpu:  All
Comment (by martinl):
 Replying to [comment:7 cmbarton]:
 > I agree with this idea. You've done a lot of work on this and I'm sure
 that these issues will ultimately be solved. But until then, I think it's
 better in the addons. As good as it is to have a krige module, it is
 better to make it an optional install than to have it a default install
 and not work.
 hm, is it really necessary? No way how to solve the problem without moving
 the module to addons and the back? Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/958#comment:8>
