[GRASS-dev] Re: [GRASS GIS] #1025: r.in.wms doesn't process WMS server responses (errors)
GRASS GIS trac at osgeo.org
Sun Apr 25 05:43:23 EDT 2010
  Reporter:  marisn       |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect       |      Status:  new
  Priority:  normal       |   Milestone:  7.0.0
 Component:  Raster       |     Version:  svn-develbranch6
Resolution:               |    Keywords:  r.in.wms
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by marisn):
 Replying to [comment:1 hamish]:
 > Also server response can come in many many forms so it is hard to check
 for with confidence.
 It's not that hard to force error messages to be returned as XML, as it is
 by default [1]. Current approach shomehow fails to detect XML error
 messages with .tiff name. Also it's not wise to get thousands of equal
 error messages.
 1. WMS 1.3.0 spec:
 7.3.3.11
 EXCEPTIONS
 The optional EXCEPTIONS parameter is defined in 6.9.4. The default value
 is
 “XML” if this parameter is absent from the request.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1025#comment:2>
