[GRASS-dev] makefile for Valgrind
Soeren Gebbert
soerengebbert at googlemail.com
Sun Apr 25 15:02:35 EDT 2010
Adding debug options should be sufficient to enable code line
traceback. AFAIK other compile options are not needed.
Best
regards
2010/4/25 Jarek Jasiewicz <jarekj at amu.edu.pl>:
> Sorry for that question
> can someone tell me how shall I modify makefile to test my program with
> Valgrind?
> adding CFLAGS=-g is enough or shall I do something else?
> thanks
> Jarek
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
