[GRASS-dev] raster engine in grass7
Glynn Clements
glynn at gclements.plus.com
Mon Apr 26 12:56:45 EDT 2010
Hamish wrote:
> > Simply copying the code from the existing libraries would place
> > it under the GPL. It would be better to have new code written
> > from scratch and placed under GDAL's MIT-style licence.
> ... it could start with copying code from the last public domain
> release, grass 4.3.
The 4.3 code doesn't support floating-point, nulls, files >2GiB,
zlib-compressed integer maps, maybe some other stuff.
Also, you'd need to separate the resampling from the actual I/O.
Writing completely new code would probably take less effort.
