[GRASS-dev] [GRASS GIS] #1045: strange behaviour in v.net.path
trac at osgeo.org
Tue Apr 27 05:58:53 EDT 2010
Reporter: manuele | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: Vector | Version: unspecified
Keywords: network analysis | Platform: Linux
Cpu: x86-32 |
Dear developers,
I found that giving a complete list of origins and destinations in a file
I obtain a different result respect giving a single couple from the
standard output. For example with the command:
> echo "26 4 9" | v.net.path am_net afcol=arc_cost out=myPathMap
I obtain this result:
"cat","id","fcat","tcat","sp","cost","fdist","tdist"[[BR]]
"1", "26","4", "9", "0", "3.0", "0.0", "0.0"
otherwise using the same network map with the different command:
> cat am_od_pair.txt | v.net.path am_net afcol=arc_cost out=myPathMap
for the same origin destination couple I obtain:[[BR]]
"cat","id","fcat","tcat","sp","cost", "fdist","tdist"[[BR]]
"26", "26","4", "9", "1", "1.79769313486232e+19","0", "0"
where it even seams that the node 9 is not reachable.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1045>
