[GRASS-dev] [GRASS GIS] #1046: Compile error in gui/wxpython using
make -j8
trac at osgeo.org
Wed Apr 28 06:37:29 EDT 2010
#1046: Compile error in gui/wxpython using make -j8
Reporter: huhabla | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: make -j8, wxGUI | Platform: Linux
Cpu: x86-32 |
Using "make -j8" for compilation produces and error in gui/wxpython.
Running make again solves the problem. Maybe a dependency issue?
make[1]: Leaving directory `/home/soeren/src/grass_dev/grass_trunk'
GRASS GIS compilation log
Started compilation: Mi 28. Apr 12:29:36 CEST 2010
Errors in:
/home/soeren/src/grass_dev/grass_trunk/gui/wxpython
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Mi 28. Apr 12:30:38 CEST 2010
make: *** [default] Fehler 1
Ticket URL: <http://trac.osgeo.org/grass/ticket/1046>
