[GRASS-dev] library not found
jzabalza at ipe.csic.es jzabalza at ipe.csic.es
Wed Apr 28 07:51:37 EDT 2010
   This is my first mail to the list, so be patience with ignorance,
please.
I am trying to compile a program from mac terminal. This program is
seemed to need some grass libraries. I write on the terminal 'make;
make install' and this is the result:
   $ make;make install
   gcc  ew_horizon.o fileio.o grassio.o  -L/lib -lm -lgrass_gis -o
ew_horizon
ld: library not found for -lgrass_gis
collect2: ld returned 1 exit status
make: *** [ew_horizon] Error 1
ew_horizon
-lgrass_gis is noted on the makefile as:
   PGM = cf7
EW_PGM = ew_horizon
CC  = gcc
CFLAGS  =
RHESSYS_BIN = /usr/local/bin
OBJECTS = main.o build_flow_table.o fileio.o find_patch.o
check_neighbours.o zero_flow_table.o \
print_flow_table.o sort_flow_table.o compute_gamma.o remove_pits.o \
find_top.o in_list.o adjust_pit.o add_roads.o find_stream.o \
find_max_flna.o find_min_flna.o route_roads_to_patches.o
compute_upslope_area.o \
print_drain_stats.o compute_drainage_density.o
compute_dist_from_road.o print_stream_table.o \
grassio.o
LIBS = -lm
GIS_LIBS = -lgrass_gis
$(PGM): $(EW_PGM) $(OBJECTS)
    $(CC) $(OBJECTS) -L$(GISBASE)/lib $(GIS_LIBS) $(LIBS) $(CFLAGS)
-o $(PGM)
$(EW_PGM): ew_horizon.o fileio.o grassio.o
    $(CC) ew_horizon.o fileio.o grassio.o $(CFLAGS) -L$(GISBASE)/lib
$(LIBS) $(GIS_LIBS) -o $(EW_PGM)
install: $(PGM) $(EW_PGM)
    cp $(PGM) $(RHESSYS_BIN)
    cp $(EW_PGM) $(RHESSYS_BIN)
clean:
    rm -f $(OBJECTS) ew_horizon.o
clobber:    clean
    rm -f $(PGM) $(EW_PGM)
print_drain_stats.o:
    $(CC) $(CFLAGS) -c print_drain_stats.c
print_stream_table.o:
    $(CC) $(CFLAGS) -c print_stream_table.c
print_flow_table.o:
    $(CC) $(CFLAGS) -c print_flow_table.c
zero_flow_table.o:
    $(CC) $(CFLAGS) -c zero_flow_table.c
in_list.o:
    $(CC) $(CFLAGS) -c in_list.c
adjust_pit.o:
    $(CC) $(CFLAGS) -c adjust_pit.c
ew_horizon.o: ew_horizon.c
    $(CC) -I$(GISBASE)/include $(CFLAGS) -c ew_horizon.c
add_roads.o:
    $(CC) $(CFLAGS) -c add_roads.c
find_top.o:
    $(CC) $(CFLAGS) -c find_top.c
find_stream.o:
    $(CC) $(CFLAGS) -c find_stream.c
find_min_flna.o:
    $(CC) $(CFLAGS) -c find_min_flna.c
find_max_flna.o:
    $(CC) $(CFLAGS) -c find_max_flna.c
remove_pits.o:
    $(CC) $(CFLAGS) -c remove_pits.c
sort_flow_table.o:
    $(CC) $(CFLAGS) -c sort_flow_table.c
build_flow_table.o: build_flow_table.c
    $(CC) $(CFLAGS) -c build_flow_table.c
compute_upslope_area.o:
    $(CC) $(CFLAGS) -c compute_upslope_area.c
compute_dist_from_road.o:
    $(CC) $(CFLAGS) -c compute_dist_from_road.c
compute_drainage_density.o:
    $(CC) $(CFLAGS) -c compute_drainage_density.c
compute_gamma.o:
    $(CC) $(CFLAGS) -c compute_gamma.c
route_roads_to_patches.o:
    $(CC) $(CFLAGS) -c route_roads_to_patches.c
find_patch.o:
    $(CC) $(CFLAGS) -c find_patch.c
fileio.o:
    $(CC) $(CFLAGS) -c fileio.c
grassio.o:
    $(CC) $(CFLAGS) -I$(GISBASE)/include -c grassio.c
main.o: main.c
    $(CC) $(CFLAGS) -I$(GISBASE)/include -c main.c
   Thank you in advance.
   javi.
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100428/345ac410/attachment-0001.html
