[GRASS-dev] library not found
Glynn Clements
glynn at gclements.plus.com
Wed Apr 28 17:34:31 EDT 2010
jzabalza at ipe.csic.es wrote:
> This is my first mail to the list, so be patience with ignorance,
> please.
> I am trying to compile a program from mac terminal. This program is
> seemed to need some grass libraries.
I strongly suggest that you use the include/Make/*.make files, as if
you were writing a module within GRASS.
You will need to set MODULE_TOPDIR, and override certain variables,
e.g. ARCH_DISTDIR, RUN_GISBASE.
