[GRASS-dev] GRASS 6.5 svn r42055 fails to build, in gui/wxpython
Maciej Sieczka
msieczka at sieczka.org
Wed Apr 28 17:30:48 EDT 2010
GRASS 6.5 svn r42055 fails to build as follows:
GRASS GIS compilation log
Started compilation: Wed Apr 28 22:45:09 CEST 2010
Errors in:
/home/src/straight/grass65/gui/wxpython
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Wed Apr 28 22:53:26 CEST 2010
make: *** [default] Error 1
So I do:
$ cd /home/src/straight/grass65/gui/wxpython
$ make 2>&1 | tee log.log
(log.log attached)
$ echo $?
0
So it seems to completes OK. What's wrong?
Debian testing amd64, Python 2.5.5, gcc (Debian 4.4.2-9) 4.4.3 20100108
(prerelease), wx 2.8.10.
Maciek
Maciej Sieczka
http://www.sieczka.org
Type: application/x-7z-compressed
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20100428/7e3c9843/log.log-0001.bin
