[GRASS-dev] Re: [GRASS GIS] #1032: ErrorCommandExecution g.proj
trac at osgeo.org
Wed Apr 28 23:13:33 EDT 2010
Reporter: sallar | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: default | Version: 6.4.0 RCs
Resolution: | Keywords: g.proj
Platform: Linux | Cpu: x86-32
Comment (by hamish):
> `gdb` ...
> `No symbol table info available`
> I installed grass by self-compile!
can you rebuild without optimization and stripping the binaries? then the
gdb output is more informative.
http://grass.osgeo.org/wiki/Bugs#Using_GDB
> My distro is Debian/lenny!
same here; but works for me. I wonder if turning on compiler optimization
(-O3) is to blame?
as per comment:8 I'm fairly stumped as to how this could happen. (unless
perhaps the stack is corrupted)
see also #827, #820, and #555 ... there is certainly a smell of smoke.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1032#comment:10>
