[GRASS-dev] Re: [GRASS GIS] #1006: r.terraflow fails to stat()
stream file on Windows
trac at osgeo.org
Thu Apr 29 01:02:09 EDT 2010
#1006: r.terraflow fails to stat() stream file on Windows
Reporter: marisn | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: Raster | Version: svn-releasebranch64
Resolution: | Keywords: wingrass, r.terraflow
Platform: MSWindows Vista | Cpu: x86-32
Comment (by hamish):
In comment:12, Hamish wrote:
> > ok, so str->stream_len() is not getting set correctly.
> > stream_len() is defined in include/iostream/ami_stream.h (number of
items in each stream)
In comment:22, Glynn wrote:
> A more portable way to determine the length of a file is to use
fseek(SEEK_END), e.g.:
long save = ftell(fp);
fseek(fp, 0, SEEK_END);
long size = ftell(fp);
fseek(fp, save, SEEK_SET);
return size;
ok, thanks. how's this:
(patch vs. 6.5svn)
Index: include/iostream/ami_stream.h
--- include/iostream/ami_stream.h (revision 41749)
+++ include/iostream/ami_stream.h (working copy)
@@ -351,21 +351,32 @@
template<class T>
off_t AMI_STREAM<T>::stream_len(void) {
+ long posn_save, st_size;
fflush(fp);
- struct stat buf;
- if (stat(path, &buf) == -1) {
- perror("AMI_STREAM::stream_len(): fstat failed ");
- perror(path);
- assert(0);
- exit(1);
+ posn_save = ftell(fp);
+ if(posn_save == -1) {
+ perror("ERROR: AMI_STREAM::stream_len(): ftell(fp) failed ");
+ perror(path);
+ exit(1);
+ fseek(fp, 0, SEEK_END);
+ st_size = ftell(fp);
+ if(st_size == -1) {
+ perror("ERROR: AMI_STREAM::stream_len(): ftell[SEEK_END] failed ");
+ perror(path);
+ exit(1);
+ fseek(fp, posn_save, SEEK_SET);
//DEBUG:
fprintf(stderr, "%s: length = %lld sizeof(T)=%d\n",
- path, buf.st_size, sizeof(T));
+ path, st_size, sizeof(T));
- return (buf.st_size / sizeof(T));
+ return (st_size / sizeof(T));
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1006#comment:24>
