[GRASS-dev] Re: [GRASS GIS] #688: wxgui - georectify: after finishing editing a point, next point should be activated
GRASS GIS trac at osgeo.org
Tue Aug 3 05:13:46 EDT 2010
activated
 Reporter:  mlennert          |       Owner:  grass-dev@…
     Type:  enhancement       |      Status:  new
 Priority:  normal            |   Milestone:  6.5.0
Component:  wxGUI             |     Version:  6.4.0 RCs
 Keywords:  wxgui georectify  |    Platform:  Unspecified
      Cpu:  Unspecified       |
Comment(by mmetz):
 Replying to [ticket:688 mlennert]:
 > In the wxgui georectifier, I think it would be more intuitive to by
 default jump to the next point in the list after having finished editing
 the previous one. Currently, you create a point, edit the projected values
 and then if you go on to put a second point, its coordinates replace those
 of the first, unless you remember to click on the next line in the list of
 points.
 Jumping to the next point in the list would be possible, but when are you
 finished editing the current point? For some points I spend some time
 adjusting them until RMS error is ok, in this case I would not want
 automatic jump to the next point. In the new Ground Control Point Manager,
 there is a confirmation dialog to prevent accidental modification.
 Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/688#comment:1>
