[GRASS-dev] Re: [GRASS GIS] #142: WinGRASS Native: Ground Control Points Usability
GRASS GIS trac at osgeo.org
Tue Aug 3 05:37:03 EDT 2010
 Reporter:  RRosario                                 |       Owner:  grass-dev@…
     Type:  enhancement                              |      Status:  new
 Priority:  major                                    |   Milestone:  6.4.0
Component:  Tcl                                      |     Version:  6.3.0 RCs
 Keywords:  wingrass ground control point usability  |    Platform:  Unspecified
      Cpu:  Unspecified                              |
Changes (by mmetz):
  * platform:  => Unspecified
  * cpu:  => Unspecified
Comment:
 1. In the new GCP Manager, there are several ways to navigate through
 points: "Go to GCP No." in the statusbar, clicking on a row in the list,
 or using up/down arrow keys when a row is selected/active. Helps?
 2. Probably no longer applies because there is an extra dialog for
 manually editing coordinates. If a point in the list is selected and the
 spacebar is pressed, this dialog appears (both Georectifier and GCP
 Manager).
 3. Does this refer to a different layout? The ticket is 2 years old, maybe
 something changed. Advancing to the next field (column) is not (no
 longer?) possible in the list, a particular entry is edited with the
 editing dialog or by clicking in the maps.
 Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/142#comment:2>
