[GRASS-dev] Re: [GRASS-SVN] r42980 - grass/trunk/vector/v.db.connect
Hamish hamish_b at yahoo.com
Wed Aug 4 02:18:25 EDT 2010
Markus Metz wrote:
> That was too fast. There is a problem with the new format. It
> works just fine for standard output for one layer, but it has
> broken some modules and wxGUI which rely on one line per layer
> in the form
> <layer/name>;<table>;<key>;<database>;<driver>
> etc.
ah, yes. it's easy to forget about layer 2+ ...
(see also r.univar + multiple input maps, similar problems)
btw, please do not add _() i18n to module output sent to stdout,
scripts parsing the result get confused. only for G_message()s.
thanks,
Hamish
