[GRASS-dev] Re: [GRASS-user] Error while creating vectorial file in WinGRASS
Hamish hamish_b at yahoo.com
Wed Aug 4 06:52:46 EDT 2010
Martin wrote:
> db.execute (and v.db.connect) is called only when user asks
> for creating attribute table in the dialog (checkbox)
ok, so the checkbox should run 'db.connect -p' and see if a DB exists, if
it doesn't create one.
proposal: add a new 'db.connect -d' flag to (re)set up the connection to
the default (like g.region has) to make this easier.
Hamish
