[GRASS-dev] Re: [GRASS-user] Error while creating vectorial file in WinGRASS
Martin Landa landa.martin at gmail.com
Wed Aug 4 07:23:15 EDT 2010
2010/8/4 Hamish <hamish_b at yahoo.com>:
> Martin wrote:
>> db.execute (and v.db.connect) is called only when user asks
>> for creating attribute table in the dialog (checkbox)
> ok, so the checkbox should run 'db.connect -p' and see if a DB exists, if
> it doesn't create one.
fixed by `db.connect -c` in r42994 and backported to all active branches.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
