[GRASS-dev] Re: [GRASS GIS] #1125: wingrass7 - ctypes - compiling error
GRASS GIS trac at osgeo.org
Wed Aug 4 17:32:48 EDT 2010
 Reporter:  hellik            |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  7.0.0
Component:  Compiling         |     Version:  svn-trunk
 Keywords:  wingrass, ctypes  |    Platform:  MSWindows Vista
      Cpu:  x86-32            |
Comment(by hellik):
 Replying to [comment:3 glynn]:
 > Replying to [comment:2 hellik]:
 > > > Does that file exist?
 > > yes, datetime.h and P_datetime.h exist in
 > It think that this is a case of MSys/MinGW (not sure which) only
 supporting one filename syntax in any given command. If you have any
 native Windows filenames, it doesn't accept MSys filenames. ctypesgen
 generates a temporary file, and passes the filename using native syntax.
 > Unfortunately, I don't know of a definite solution. Forcing
 Platform.make to use Windows syntax (i.e. c:/osgeo4w/...) exclusively
 might work. I don't know if this can be achieved solely through the choice
 of configure switches, or whether you would need to edit Platform.make
 manually.
 anything that we can test?
 Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1125#comment:6>
