[GRASS-dev] Documentation about Directed Graph Library (DGLib)
Martin Landa
landa.martin at gmail.com
Thu Aug 5 11:27:02 EDT 2010
2010/8/5 rabotin <rabotin at supagro.inra.fr>:
> Thanks for the fast answer but for lots of dglib functions (like dglGetEdge)
> there is no documentation . Do you if it's possible to have additional
> documentation. I've searched for grass add on scripts which can use dglib
> library (or work with graph concepts) to have some tips from these scripts
> but i found only v.strahler and it seems that this code doesn't use the
> dglib library.
right, unfortunately the most of the dglib functions are not
documented at all or doxygen strings are missing. We are looking for a
volunteer for updating the dglib documentation.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
