[GRASS-dev] Re: [GRASS GIS] #1125: wingrass7 - ctypes - compiling error
GRASS GIS trac at osgeo.org
Thu Aug 5 12:03:10 EDT 2010
 Reporter:  hellik            |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  7.0.0
Component:  Compiling         |     Version:  svn-trunk
 Keywords:  wingrass, ctypes  |    Platform:  MSWindows Vista
      Cpu:  x86-32            |
Comment(by glynn):
 Replying to [comment:7 hellik]:
 > if I don't unset manually large file support in platform make, I get
 similar error message like Martin.
 > but the problem seems to be the same:
 > => [...]grass\datetime.h:28:30: grass/P_datetime.h: No such file or
 directory
 Except, Martin isn't getting this error.
 The Python backtrace is irrelevant; just about any error causes that
 backtrace.
 As a general rule: only the first error means anything. Any subsequent
 errors should be assumed to be symptoms unless there is a specific reason
 to believe otherwise.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1125#comment:9>
