[GRASS-dev] 6.4.0 blocker bugs
Maris Nartiss
maris.gis at gmail.com
Mon Aug 9 12:34:01 EDT 2010
A request for quickfix:
I'm requesting permission (as we are so close to release) to backport
r43023 to 6.4. It fixes r.mask failure to remove MASK if GISDBASE
contains spaces in path. [1]
As I'm leaving town right now, in case of OK, somebody, please, do backporting.
Thanks.
Maris.
1. http://trac.osgeo.org/grass/changeset/43023
2010/8/9, Markus Neteler <neteler at osgeo.org>:
> On Mon, Aug 9, 2010 at 4:43 AM, Hamish <hamish_b at yahoo.com> wrote:
>> Markus Metz wrote:
>>> It's a bit late, but no blocker bugs are left apart from
>>> writing the release announcement.
>> well it's written, as is the blurb. look in grass-web/
>> announces/ for drafts. please proof read, comment, etc.
>> (see earlier post about that from last weeks, ticket)
> The current state is here:
> http://svn.osgeo.org/grass/grass-web/trunk/announces/announce_grass640.html
>> That means it's possible, as long as nobody is slowing it
>>> down.
>> two changes I will try to make tonight: backport Paul's
>> g.proj linebreak fix to 6.4 and edit the menu label for
>> v.in.mapgen (it's Matlab compatible ascii, not Matlab
>> format per se). I do not plan on backporting r.in.wms
>> and r.tileset patches as there have been reports of
>> m.proj/cs2cs problems from them.
>> and one last read through of forgotten bug reports.. :)
> great, we are finally close :)
> We need to notify the binary packagers unless they don't read
> here to get binaries out at the same time (ideally we put out the
> source code ball without announcement, package and publish
> as much as possible at the same moment).
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
