[GRASS-dev] About v.distance, v.what.vect (wrt "count points
within...").
Moritz Lennert
mlennert at club.worldonline.be
Tue Aug 10 09:17:19 EDT 2010
On 10/08/10 13:49, Nikos Alexandris wrote:
> Markus M:
>> If a point is inside an area (the polygon composed of the area's
>> boundaries), the distance is 0 (zero):
> This sentence makes me think that it is a priori known (based on something
> else - related to topology?) when a point is inside an area. Why all the need
> to measure distances then in order to count how many points are inside?
As you can see in the code referenced by Markus, there is a
Vect_point_in_area(), so yes, it is possible to more directly check if
points are in areas. It all depends on which modules were written using
this function. At this stage all point-in-polygon attempts in GRASS are
scripts using workarounds...
>> A centroid is always inside the area it belongs to, therefore the
>> distance of a point outside an area to the area's centroid is always
>> larger than the distance of that point to the area's boundaries.
> What happens when the centroid (gravity center) falls outside of the
> boundaries?
In GRASS, by definition a centroid is within the boundaries, and so does
not necessarily represent center of gravity.
>>> Point to boundary? Specifically, point to all-lines that compose a
>>> boundary? Many distances? And then, keep the maximum?
>> If a point is outside an area, v.distance determines the shortest
>> distance to the area's boundaries (point to all-lines that compose a
>> boundary), IOW, keep the minimum not the maximum because v.distance
>> searches for the nearest feature.
> All right. But, (repeating the same question): why is distance measuring
> required at all? To compare it with what?
Well, v.distance was not meant as a point-in-polygon measurement tool,
but as a distance measurement tool. v.what.vect just "abuses" it as
such, using dmax=0.0. But currently, there is not dedicated
point-in-polygon counting module...
> Why are (supposedly) other tools faster in counting points within polygons?
see above...
So, maybe, if you have a dedicated programmer at hand, you could imagine
a module with point-in-polygon algorithm, maybe giving the option of
counting the points, aggregating some attribute values of the points,
etc, using the Vect_point_in_area() function...
Should just be a matter of:
- opening a polygon and a point layer
- for each polygon
- loop through all points and if Vect_point_in_area() is true,
aggregate the values of those that fall into the polygon
- put results into table of polygon map, new table or stdout
I imagine that here the use of bounding boxes and the spatial index
might here, but that's Markus' specialty ;-)
Moritz
