[GRASS-dev] [GRASS GIS] #1130: Request for a v.count.points grass module
GRASS GIS trac at osgeo.org
Tue Aug 10 10:27:52 EDT 2010
 Reporter:  nikos                                                              |       Owner:  grass-dev@…
     Type:  enhancement                                                        |      Status:  new
 Priority:  normal                                                             |   Milestone:
Component:  Vector                                                             |     Version:  unspecified
 Keywords:  count points in areas, v.count.points.sh, v.what.vect, v.distance  |    Platform:  Unspecified
      Cpu:  Unspecified                                                        |
 Currently there is no dedicated grass module to return the number of
 points that fall inside an area. Although there is a specific function to
 check if points fall within an area [1], the task is performed indirectly
 using v.what.vect [2] (which in turn is a wrapper to v.distance) in a
 script (e.g. v.count.points.sh [3]). Indirect methods (such as the
 previously mentioned script) work fine but take (impractically) too long
 when using (very) large point and area vector maps.[[BR]]
 Counting points is rather a common task within the framework of GIS.
 Therefore, it probably makes sense to have a native (faster and easy to
 use) grass module that returns the number of points within area(s) and
 optionally carry over attributes from the area to the point map (like
 v.what.vect) or/and vice versa. Potentially, such a module can replace
 completely the v.what.vect script (?).[[BR]]
 A discussion upon the subject is to be found in the grass-dev mailing list
 [4].[[BR]]
 [1]
 http://grass.osgeo.org/programming7/vector_2Vlib_2area_8c.html#a20344aaee88bf684dccdd2071da0851d
 [[BR]]
 [2] http://svn.osgeo.org/grass/grass/trunk/scripts/v.what.vect/ [[BR]]
 [3] http://wiki.iosa.it/dokuwiki/spatial_analysis:feature_count [[BR]]
 [4] http://lists.osgeo.org/pipermail/grass-dev/2010-August/051471.html
 [[BR]]
Ticket URL: <http://trac.osgeo.org/grass/ticket/1130>
