[GRASS-dev] Re: [GRASS GIS] #1125: wingrass7 - ctypes - compiling error
GRASS GIS trac at osgeo.org
Wed Aug 11 15:22:33 EDT 2010
 Reporter:  hellik            |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  blocker           |   Milestone:  6.5.0
Component:  Compiling         |     Version:  svn-trunk
 Keywords:  wingrass, ctypes  |    Platform:  MSWindows Vista
      Cpu:  x86-32            |
Comment(by mmetz):
 Replying to [comment:14 glynn]:
 > Replying to [comment:13 martinl]:
 > > > BTW, is there a way how to disable LFS? - {{{--disable-largefile}}}
 doesn't seems to work.
 > > using {{{--disable-largefile}}} I am getting on *MS Windows*
 > checking for _LARGEFILE_SOURCE value needed for large files... no
 > checking for fseeko... no
 > checking if system supports Large Files at all... yes
 > > and
 > USE_LARGEFILES      = 1
 > > Not sure why it's not working on MS Windows.
 > The "meta" answer is: because the code was lifted wholesale from
 cdrtools without any attempt at understanding it.
 Well, let's make an attempt at understanding it. For grass 7, I suggest to
 remove the --enable-largefile configure option and issue a warning if LFS
 is not available. Global LFS for grass 7 is already there, for Linux and
 Mac. For wingrass, it's coming soon, but I will need some help.
 This reply belongs to a new thread, I'll open one.
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1125#comment:15>
