[GRASS-dev] About v.distance, v.what.vect (wrt "count points within...").
Markus Metz markus.metz.giswork at googlemail.com
Fri Aug 13 06:42:57 EDT 2010
Nikos Alexandris wrote:
> Markus M:
>> I've put a new module in grass-addons, called v.vect.stats.
> ... The
> module fails to compile though under grass64, grass_trunk
compiles now in 64, but no longer in 65 (stats library in 65 is
different from 64), 65 is a development version and will probably
never be an officially stable version
does not compile in trunk because it's written for 65, now 64
Markus M
