[GRASS-dev] Re: [GRASS GIS] #1125: wingrass - ctypes - compiling
error
trac at osgeo.org
Sun Aug 15 14:29:09 EDT 2010
#1125: wingrass - ctypes - compiling error
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.5.0
Component: Compiling | Version: svn-trunk
Keywords: wingrass, ctypes | Platform: MSWindows Vista
Cpu: x86-32 |
Comment(by glynn):
Replying to [comment:20 hellik]:
> I get now a different error message than the first report
Error: gcc -E -D_FILE_OFFSET_BITS=64
-I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include
-I/c/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/include:
c:\osgeo4w\usr\src\grass_trunk\dist.i686-pc-
mingw32\include\grass\gis.h:28:26: grass/config.h: No such file or
directory
I think that I've fixed this with r43120, which invokes the preprocessor
via sh.exe. This is the only way I can find to get the -I switches to be
recognised. Using Windows pathnames in the Platform.make doesn't work
because $PATH doesn't like colons in filenames.
Warning: Could not load library "intl". Okay, I'll try to load it at
runtime instead.
Ugh. ctypesgen can't handle the -lintl flag, as it's an import library
(libintl.dll.a); the actual DLL is libintl3.dll. r43121 adds a workaround
for this.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1125#comment:21>
