[GRASS-dev] Re: [GRASS GIS] #1125: wingrass - ctypes - compiling error
GRASS GIS trac at osgeo.org
Wed Aug 18 02:39:54 EDT 2010
 Reporter:  hellik            |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  blocker           |   Milestone:  6.5.0
Component:  Compiling         |     Version:  svn-trunk
 Keywords:  wingrass, ctypes  |    Platform:  MSWindows Vista
      Cpu:  x86-32            |
Comment(by glynn):
 Replying to [comment:22 hellik]:
 > There is only the tcltk-nviz available. Is there any change to test the
 fixes for example r43120 and r43121.
 Both of those changes affect the building of the wrappers. They should fix
 the Windows build-time errors which prevented usable wrappers from being
 generated (you still get some errors about `__asm__` and similar, but
 those don't matter).
 r43120 should fix the 'grass/config.h: No such file or directory' (etc)
 errors, while r43121 should fix the 'Could not load library "intl"'
 warnings (which will result in errors at runtime).
 Currently, the only available test for the wrappers is the wx nviz module,
 although that could fail on Windows for reasons unrelated to ctypes (e.g.
 issues with the underlying OpenGL support).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1125#comment:23>
