[GRASS-dev] [GRASS GIS] #1133: ps.map doesn’t accept more than 10 ‘labels’ instructions
GRASS GIS trac at osgeo.org
Fri Aug 20 05:13:02 EDT 2010
 Reporter:  clerici      |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.0
Component:  default      |     Version:  6.4.0 RCs
 Keywords:               |    Platform:  Linux
      Cpu:  Unspecified  |
 To check  with Spearfish data:[[BR]]
    v.label labels=archlab map=archsites column=str1[[BR]]
    ps.map in=label.txt out=archlab.ps
 label.txt (with 11 labels instructions):[[BR]]
    labels archlab[[BR]]
    end[[BR]]
    end[[BR]]
    end[[BR]]
    end[[BR]]
    end[[BR]]
    end[[BR]]
    end[[BR]]
    end[[BR]]
    end[[BR]]
    end[[BR]]
    end[[BR]]
 The error message is:[[BR]]
    ERROR: archlab in esercizi : no more label files allowed[[BR]]
 With less than 11 labels instructions the ps map is successfully
 created.[[BR]]
 Greetings[[BR]]
 A. Clerici
Ticket URL: <http://trac.osgeo.org/grass/ticket/1133>
